thanks alot to those that have helped me in the last month or so, and to the ones that played dad i am appreciative but you failed miserably i havent had a father figure in the last 27 of my 30 years, so i wont be missing the preachings on how bad i type or what im not ready for. well im off to find out how to build MY 4RUNNER THE WAY I WANT IT AND THE WAY I THINK IT SHOULD BE. thanks again to the peeps that tried to be helpful and to the others try harder and you know you are cause the post probably will upset you in one way or another lack lack of caps at the begining of a sentence or my lack of spelling or my defeatest attitude. just looking for answers but i see there are no more here have a good one
i see there are no more here? That ain't good anglish!
Lighten up, life is not that bad. If you can't take a little criticizism (?), your road will be long and your mpg will be low.
Good luck and build your "4RUNNER THE WAY I WANT IT AND THE WAY I THINK IT SHOULD BE".
XXXOOO
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top. '88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
No one said don't go with a sas they said try a ifs first. Why waste the money on a sas if you REALLY don't need it. Solid axles are better if you get rid of the birfields. Birfields are just as week as the cv axles. The sas will give more flex and is cheaper to lift after the swap, but disadvantages are the diff. gets caught on everything. If you do a 4" lift on both and put 33s on the ifs will have a higher ground clearance in the front because the spindles push the tires down and leaf springs will push the whole axle 4" lower. Usually u can run taller tires with the sa though. And i do know that the ifs does come with diff drop brackets to keep cv axle angles the same but the kits i have seen did not use 4" drop brackets.
But who really cares anyway just tried to help you.
SO JUST SHUT THE F*** UP AND BYE!!!!!!!!!!!
There's a couple of knuckleheads on every forum, ya just gotta ignore them. If you're getting emails you don't want, list that sender as a spammer in your email program or something. You should be able to block them, one way or another.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
