Valve Cover Removal Help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2005, 04:26 PM   #1 (permalink)
View lawnboy1200's Photo Gallery
I have a 89 pickup with the 22re and I am in the process of changing the valve cover gasket. I have removed all bolts from the cover and i have even tried tapping the cover with a piece of wood and a hammer, but to no success. Does anybody know of any bolt im missing? I have removed the 4 main nuts from the top and all the vaccuum and breather lines. Any help would be appreciated! thanks in advance!
lawnboy1200 is offline
Old 05-19-2005, 05:35 PM   #2 (permalink)
View YumaBill's Photo Gallery
Hi
When I first got my truck 22re it had 120,ooo miles on it and I had to give it a pretty good rap with a rubber mallet ( it had been on for some time I guess LOL
There are only the 4 nuts on top of the cover on mine the rubber seal between head and cover just was stuck pretty good also I have seen people use rtv sealant on there also.
good luck
YumaBill is offline
Old 05-19-2005, 06:50 PM   #3 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
You usually have to unscrew the rubber seals to remove the cover.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 05-19-2005, 07:52 PM   #4 (permalink)
Whew i was about to go crazy but i finally got it off! Thanks texas 12 for that post; those rubber gaskets were the problem. i got it all cleaned off, new gasket on, rtv on, and its all back together so only time will tell if i did the job right lol! Thanks everybody for their help!
Old 05-20-2005, 12:06 PM   #5 (permalink)
Nobody Special
View 390FE's Photo Gallery
I had the same problem but figured it out after snapping a screw driver in half.
Is it recomended to replaced those screw on rubber gaskets after removal. I used a flat blade and tried not to nick the rubber but I saw to other way to unscrew them.
The valve cover is off right now and so is the head. Hopefully picking up new(used) head tomorow and waiting on the timing set to show up.
'93 Ge-ota Corr-izm (totaled)
'87 Toyota P/U 22r (sold)
'09 Corolla S (g/f's)
2 non Toyota's
390FE is offline
Old 05-20-2005, 01:39 PM   #6 (permalink)
Yours are differnet than mine.
on mine they are just rubber spacers/seals with brass tops that slide over the bolt inbetween cover and nut
sorry for the dissinformation.
YumaBill is offline
