There is a oil pressure switch there right now. You will need to install a oil pressure sending unit but it has to be matched to the guage you are going to use. If you do a cluster swap, then you use a Toyota (nippon denso) sender. If you buy an aftermarket guage, you need to get the appropiate sender. Should be standard pipe thread but I do not know the exact size.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
