Gas trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2005, 09:11 AM   #1 (permalink)
TOYO-MAN
View sonofmayhem's Photo Gallery
Gas trouble
I have gotten bad gas mileage 10-12 instead of 18-22. And this issue is starting to piss me off. My dad was looking at the engine and he said i had gas leaking at the valves???? Could this be true, and if so what would need to be done to stop the leak. Thanks
85, lifted and ready to rock!
sonofmayhem is offline
Old 05-29-2005, 12:14 PM   #2 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
FI or carb'd?
If your Dad says it is leaking at the valves, go with the experience and ask him for help. He has seen the problem. We would just be guessing.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 05-29-2005, 11:30 PM   #3 (permalink)
TOYO-MAN
It is EFI, we were fixin the plugs and he said he could smell the gas in the engine bay, and he saw some by the valves. So i just hope it is not to hard or time consuming. Thanks
Old 06-04-2005, 04:27 PM   #4 (permalink)
TOYO-MAN
So does anyone know how to stop the leak, get to the valves, or how much does a rebuild usually run.
Old 06-04-2005, 09:02 PM   #5 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
Perhaps you just need a new valve cover gasket.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 06-05-2005, 10:59 AM   #6 (permalink)
TOYO-MAN
how hard would that be to replace, how much.
Old 06-05-2005, 01:02 PM   #7 (permalink)
Toyota Fanboy
Bakemono's Avatar
Not hard to replace. All you have to do is remove the valve cover, remove the old gasket, put on the new one and reinstall the valve cover.
Cost? Id bet its under $50.
Cap'n
'07 Toyota Camry LE
Bakemono is offline
Old 06-05-2005, 02:35 PM   #8 (permalink)
TOYO-MAN
thanks. hopefully this will work..if it doesnt could there be another gasket or way to stop the leak?
Thanks
Old 06-05-2005, 05:18 PM   #9 (permalink)
Toyota Fanboy
Bakemono's Avatar
Well, if you dad said its leaking "at the valves", that would be my guess. Its hard to say without actually seeing the truck in person.
Feel like driving to southern Wisconsin? LOL Id be more than happy to take a look at it for you.
Cap'n
'07 Toyota Camry LE
Bakemono is offline
Old 06-05-2005, 06:26 PM   #10 (permalink)
TOYO-MAN
Thank you for all your help.. Ill have to bust into it next week. Anything i should be careful about.
Old 06-06-2005, 04:54 PM   #11 (permalink)
Toyota Fanboy
Bakemono's Avatar
Just make sure that if you have to scrape off some of the old gasket that you keep the debris out of the valvetrain.
Cap'n
'07 Toyota Camry LE
Bakemono is offline
Old 06-07-2005, 02:39 AM   #12 (permalink)
tacojet's Avatar
View tacojet's Photo Gallery
The valve cover gasket has nothing to do with fuel. I would start with cleaning out the injectors, try a can or two of Seafoam.
This is my ritual on our Camry and will be on our Taco when it gets old. I warm the car up and then pull the vacuum line off of the brake booster, with the engine running, and suck about 1/3 of the can slowly into the intake. Do it slowly or the engine will die. Shut the engine down and wait 15 minutes, while you are waiting pour the rest of the can in the gas tank. Fire the engine up after 15 minutes and drive it around for a while, at least until it stops smoking from the Seafoam.
This will clean out the injectors, O2 sensor, etc. I would at least try it before I tore into the engine or even the injectors. Start simple and go from there.
tacojet is offline
Old 06-07-2005, 09:31 AM   #13 (permalink)
TOYO-MAN
Sounds good, but will that solve a leak? plus the gasket is only 10 bucks and i wanna learn how to do it over summer, when i dont need my truck
Old 06-07-2005, 04:32 PM   #14 (permalink)
Toyota Fanboy
Bakemono's Avatar
If his dad said its leaking gas "by the valves" Im not sure how else it would leak. Its hard to really say 100% without actually seeing the truck in person.
It could be leaking by one of the injectors, he could have a pinhole in his fuel rail or it could be coming out from any number of locations.
Cap'n
'07 Toyota Camry LE
Bakemono is offline
Old 06-07-2005, 04:40 PM   #15 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135623
View Hajoca's Photo Gallery
On my dad's old accord with PGM FI ( 1 injector per cylinder) the injector seals were getting old and gas would seep out... as the fuel supply line and fuel rail would be pressurized, even after the car was off. So every time the engine was stopped, the gas would slowly seep and evaporate out.
$26 dollars worth of injector seals (one o-ring at fuel rail and 2 at the intake manifold) the problem was gone!
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is offline
