Wheel balance PROBLEM
Question: I have 97 4 Runner V6 2WD( which I love, great vehicle ) had 15” stock wheels on when I bought it. I put American Racing Wheels on,16" and BIG " O " tires 275 x 70 x16" no problem. Wore the tires out replaced at another tire dealer ( no name as yet )( their personal brand ) same size tires. Always couldn't get a good balance. Each time out a little more and each rotation they got worse the hopping at the rear after one rotation moved to the steering wheel now it vibrates. Rebalanced at least 10 times finally THEY replaced the 2 front tires saying THEY found a bad tire with 2 new ones. This made the front end worse, rebalance 3 more times finally THEY said THEY would like to put a different brand on same size. This made it worse again. ( I have gone to the BIG “ O “ center at a fair distance from my area to have them check front end and got an OK, NO PROBLEM. I NEVER hit curbs or go off road, side walls never hit curbs. When BIG “O “ took the front tires off and checked the balance they said it was off (due to 2 weights coming off on my way to their store). When they replaced the wheels ( same wheel on same side )it was a little better ( FUNNY ). Back to the tire store rebalance again rear tires VERY little weight on them front tires ALOT of weights. Is the front end of this vehicle SO sensitive that nothing but a perfect balance will work?. I am at my end trying to be patient with this distributor ANY SUGGESTIONS?????????????????.A
XLB
