torquing a head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2005, 03:50 PM   #1 (permalink)
View papaw's Photo Gallery
torquing a head
Hi, I am replacing a blown head gasket and I am wanting to know how much to torque the head bolts when I replace them, also is there a certain order in which to tighten the head bolts or do you start in the middle and work your way out? Oh Yea! it is a 1994 pickup, 4 cylinder. Thanks Papaw
papaw is offline
Old 06-04-2005, 09:38 AM   #2 (permalink)
View YumaBill's Photo Gallery
I assume that you have a 22re. yes there is an order to tighten and there is also 3 steps that have to be followed when I get home I will check the #'s and postem up should be a few hours.
YumaBill is offline
Old 06-06-2005, 10:34 PM   #3 (permalink)
Thank you, I would appreciate your information
papaw is offline
Old 06-06-2005, 10:50 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
ur correct...torque from the inside out in the sequence that YumaBill is getting for you. do it in 3 stages. example: if torque value was 90ftlbs, then do all @ 30lbs, the again @60lbs and then again @90lbs
The Jedi Speeder at CarDomain
MR2Jedi is offline
Old 06-07-2005, 07:04 PM   #5 (permalink)
Nobody Special
View 390FE's Photo Gallery
Its also recomended to get new head bolts because they actually stretch as you torque them and teh bolt itself acts like a lock washer.
'93 Ge-ota Corr-izm (totaled)
'87 Toyota P/U 22r (sold)
'09 Corolla S (g/f's)
2 non Toyota's
390FE is offline
Old 06-07-2005, 08:00 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
yep,,,, ARP's -about $100.00 set
MR2Jedi is offline
Old 06-09-2005, 12:31 PM   #7 (permalink)
View EasyCo's Photo Gallery
I just replaced my head gasket on my '90 Toyota pickup.
It's 48lbs/ft per stud and the tightening pattern is going by an X.
So you have
1 2 3 4
5 6 7 8
You torque, 1-8, 5-4, 2-7, 6-3, then retorque.
EasyCo is offline
Old 06-10-2005, 11:24 AM   #8 (permalink)
Nobody Special
I thought you started in the middle and worked out. And I also thought there were 10 bolts???
12345
67890
and torque 3-8 2-9 7-4 1-0 6-5 ??????????????????
2 non Toyota's
390FE is offline
Old 06-10-2005, 02:11 PM   #9 (permalink)
Nobody Special
I quickley looked at the book at lunch and there are 10 bolts.
Do the pattern I showed but keep going side to side when tightening.
2 non Toyota's
390FE is offline
Old 06-10-2005, 02:36 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
12345
67890
this is correct
MR2Jedi is offline
