Driving Stick - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2005, 10:36 PM   #1 (permalink)
View madtodaimax's Photo Gallery
Driving Stick
I would like to know your opinion on the proper way to drive a manual transmission. Is stepping on the clutch shifting, and releasing the pedal good enough? Or is there a need to double clutch, which is from what i understand, stepping on the clutch, shifting into neutral, releasing the clutch, waiting a second, stepping on the clutch, shifting, and letting go?
madtodaimax is offline
Old 06-01-2005, 10:51 PM   #2 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
Going up through the gears, clutch, shift, add some gas and unclutch is good enough.
Double clutching is mainly for downshifting.... depends on how old your car is.
BenG is offline
Old 06-02-2005, 03:18 AM   #3 (permalink)
View karugs's Photo Gallery
Your first method works best. Just add "step on gas" as the last step so the car won't stall.
karugs is offline
Old 06-02-2005, 07:31 AM   #4 (permalink)
Gameroom cash: $249045
View toto's Photo Gallery
I've never driven a manual trans on a truck, but for years I had cars with it. I never "double-clucthed"... the regular process works fine. I traded in a Mazda GLC (now known as the Mazda 3) with 85,000+ miles and the original clutch!
2009 Tacoma DC SB TRD Sport 4x4
Retired: 2000 Tacoma Xtra Cab V6 TRD Off Road 4x4
toto is offline
Old 06-02-2005, 08:21 PM   #5 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
Basically: take your foot off the gas, push the clutch pedal in, shift, relase the clutch pedal, put your foot back on the gas.
With modern manual trannys you dont need to double clutch because manual trannys nowdays have gear synchros. Back in the '70s, when trannys had straight-cut gears, you had to double clutch to match the revs otherwise you would be constantly grinding the gears.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 06-02-2005, 09:22 PM   #6 (permalink)
View black93DX's Photo Gallery
The only thing difficult about driving a manual trans early Toyota pickup is you really have to know how to drive it, i.e. clean shifting when entering traffic because of the lack of power, having a quick clutch foot, and knowing how long to hold revs to get the most power out of the motor...
93 DX Ext. Cab.- 5 speed,FM40,K&N,31x11.50 RVT's
black93DX is offline
Old 06-03-2005, 12:48 PM   #7 (permalink)
View EnolaGaia's Photo Gallery
As already mentioned - double clutching is generally unnecessary nowadays because modern manual transmissions have working synchronizers.
It doesn't hurt to know how to double clutch, though... If something goes bonkers with your tranny - especially if a synchro gets weird on you - it might be handy to know how to double clutch to work around it.
Even with synchros, I still double clutch when doing rapid downshifts (to rev the engine back up to better mesh and more smoothly decelerate when I engage the next-lower gear...).
EnolaGaia is offline
