The target air fuel ratio of 14.7 to 1 (stoichiometric) is achieved by adjusting injection duration. Injection duration is the sum of the preprogrammed basic injection time plus corrections. If no correction is needed the voltage signal from the O2 sensor should be 2.5 volts. The voltage across the sensor varies with the oxygen content of the exhaust. Voltage higher than 2.5 volts (up to 5 volts) indicates that the ECU is decreasing fuel (shortening the injection duration) to correct for a rich condition and voltage less than 2.5 volts indicates the ECU is increasing fuel (increasing injection duration) to correct for a lean condition. Things that can cause a rich condition are ignition misfire, high fuel pressure, etc. Things that can cause a lean condition are worn TPS shaft, vacuum leaks, low fuel pressure, etc. The ability of the system to adjust itself based on sensor feedback is called a closed loop system. The closed loop mode only operates when the engine is at operating temperature and the IDL contacts are off (throttle open).
To test the system you need a voltmeter and 5-kohm resistor and make some spade type jumpers. Short out T and E1 and read the codes first. Fix any problem indicated by the codes then clear the codes by removing the EFI fuse for a minute. Warm up the engine and connect a voltmeter to Vf and E1. Run the engine at 2,500 RPM for at least 2 minutes. Perform all the tests with the engine running at 2,500 RPM. Short out terminals T and E1. Count the number of voltage pulses in 10 seconds.
Six or more pulses: System tests normal. Now unshort the T and E1 terminals and measure the voltage. A reading around 2.5 volts means everything is normal. A reading high or low means something might be wrong other than the EFI system that is effecting the A/F ratio.
Less than 6 pulses: Unshort the T and E1 terminals and measure voltage. If you get any voltage replace the O2 sensor. Pull off the PCV hose and measure voltage. If still you get 0 volts replace the O2 sensor. If you get more than 0 volts you have something causing an over rich condition. O2 sensor is working normal.
No pulses: Unshort the T and E1 terminals and measure voltage. If you get 0 volts then pull off the PCV hose and measure voltage. If you still get 0 volts replace the O2 sensor. If you get more than 0 volts you have something causing an over rich condition. O2 sensor is working normal. After unshorting the T and E1 terminals you get more than 0 volts disconnect the water temperature sensor and connect a 5-kohm resistor across the connector. Measure voltage. If you get 0 volts replace the O2 sensor. If you get 5 volts or close something in the engine is causing an over lean condition. O2 sensor is working normal.
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiB...pair_guide.jsp
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
http://www.showmesome.info/hilux/info/manuals/1KZ-TE
http://surf.mactherapy.com/1KZ-TE.pdf
http://surf.mactherapy.com/parts/
http://www.spyderchat.com/1zzfe.pdf
http://files.matrixvibe.net/docs/1zzfe.pdf
http://landcruiser.free.fr/mans/
http://www.turbosupras.com/pages/technical/tsrm.htm
http://www.lieblweb.com/tacoma/Mecha...rams/index.htm
http://perso.wanadoo.fr/adherence.4x...techniques.htm
http://perso.wanadoo.fr/adherence.4x4/index.htm
http://www.asatraction4x4.cl/html/
http://www.toyotasurf.asn.au/techsite/downloads.htm
http://www.grubinski.com/grubinski/a...oyota.manuals/
http://www.carsoft.ru/files/4runner95di.exe
http://www.hotrodder.com/kwkride/tech.html
http://www.autoshop101.com/autoshop15.html
http://www.mtv411.com/sitemap.htm
1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
2003 (2001-2004) Toyota Tacoma Factory Service Manual:
http://fsm.afraid.org/
http://www.junglecode.com/toyota/tacoma/2003_fsm/
http://65.200.1.6/FSM/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 244 000 KM
