rear end makes a howling sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2005, 12:04 AM   #1 (permalink)
View 84Toyota's Photo Gallery
Question rear end makes a howling sound
Hello I have a 1984 Toyota pickup, rear wheel drive
At higher speeds the rear end makes a howling sound.
I’ve narrowed it down and I’m 99% sure it’s worn
gears in the differential carrier, instead of replacing bad gears
Someone told me to buy another carrier from a wrecker
And replace the entire thing.
My question is if I replace the carrier with a good one
Is that likely to solve the problem?
or is there anything more in the axle that could be
contributing to the sound?
84Toyota is offline
Old 06-18-2005, 03:07 PM   #2 (permalink)
View qsd-dan's Photo Gallery
Well, it would definately be worth checking the axle bearings as they can give the same symptoms. Much cheaper and more common of a problem unless you have an ungodly amount of miles on it or it has been abused to hell. Have you checked or changed the gear oil latley? I know people with 600,000 miles on the original rear end on these trucks
qsd-dan is offline
Old 06-18-2005, 05:57 PM   #3 (permalink)
Thanks for the reply.
My manual is hardly covering anything
To do with this problem
It has 182,000 k.
It makes the howling sound only when accelerating.
I’ve changed the oil still no improvement. The truck
has bean doing this since I got it.
For checking the axel bearings do I have to take everything
apart or is just checking for play enough?
84Toyota is offline
Old 06-19-2005, 02:41 AM   #4 (permalink)
Uh-oh, sounds like you are correct with your diagnosis. I have found an interesting article that may prove that you are correct.
http://www.ringpinion.com/content/te...lt.asp?pid=109
qsd-dan is offline
