Hard 4x4 engaugement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2005, 10:47 PM   #1 (permalink)
Official Saipan Member
rogerman's Avatar
View rogerman's Photo Gallery
Question Hard 4x4 engaugement
Hey all i got a slight problem with my 92 4x4 its a 22R-E with the chain transfercase. Here is my prob: after locking the hubs depressing the clutch the 4x4 shifter is either; hard to engauge and hard to disengauge(hard like apply alot of force) or easy to engauge hard to disengauge idk what the hell is wrong with it 4wd works fine got me out of tons of situations but the shifter idk. Feel free to say anything.
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
rogerman is offline
Old 06-19-2005, 12:12 PM   #2 (permalink)
Bring On The MUD!!!!!
Geius Maniacal's Avatar
View Geius Maniacal's Photo Gallery
i have the same problem in my 90. some how i always seems to get into whatever drive i needed but i have the same problem. so im a little curious on the solution to this one.
!!!SOLD!!! '83 SR5 w/ Cummins 4BT Turbo Diesel *Under Cons.* 6in Susp. and 3in Body lift on 35's
'99 Dodge Ram 2500 5.9L Cummins BD Super-B, CDT2, Custom 47RE, Adrenaline w/ Pulse, BD Hot Rod VP44, Airdog 165, BD XXX-Pulse 125's, Isspro EV2's
Geius Maniacal is offline
Old 06-19-2005, 03:15 PM   #3 (permalink)
reb
View reb's Photo Gallery
You shouldn't have to disengage the clutch to go from 2wd high to 4wd high, even while on the move. If you are having problems engaging it on the move, I would suspect significantly different tire pressures between front and rear (assuming all four tires are the same size). Difficulty in disengaging the front axle can be the result of running the truck in 4wd on a hard surface. The easy fix for that situation is to back up a bit, then try again to disengage it. The clutch would have no effect on the problem.
I have heard of at least one case where someone had changed one of the differentials to a different ratio. That would cause the problems you describe, and more. I assume yours is stock.
reb is offline
Old 06-19-2005, 04:16 PM   #4 (permalink)
i know that i have disengaged it after backing up a few times so that is a solution. none of the things u said r true of me truck tho. tires r fine, never use it on hard surfaces, and my differentials r stock.
Old 06-19-2005, 04:47 PM   #5 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
I had an '85 4Runner with a similar problem. It would go into 4x4 very easily but it was hard to make it disengage.
I really never solved the problem, I would just give it a good hard pull on the t-case lever and it would usually pop right out.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 06-19-2005, 05:11 PM   #6 (permalink)
Under the hood...
FineWynsFJ40's Avatar
View FineWynsFJ40's Photo Gallery
Similar situation with my Land Cruiser. It's in the gearing and synchromesh. If it is hard to shift (either into or out of), move the transmission shifter to neutral, then let up on the clutch to spin the gears in the transfercase, then depress the clutch and shift again. This is the same principle for unsynchronized reverse, like my H41 transmission. It's because the synchro is worn, so when the gears are spinning it will be easier to shift into and out of 4x4. Just make sure to not spin them too fast!
1974 FJ40, near end of restoration. Ready to hit the beaches, roads, and finally hit the trails. Especially the trails.
http://www.cardomain.com/ride/464154
~ Drive A Legend, Drive A Land Cruiser ~
FineWynsFJ40 is offline
Old 06-19-2005, 05:52 PM   #7 (permalink)
View Sidney's Photo Gallery
As stated in the owner's manual drive backwards for at least 10 feet to disengage the 4wd.Another technique that I use is accelerate forward then quickly release the gas pedal then activate the transfer case lever.
http://www.showmesome.info/hilux/info/faq.htm
I copied & pasted the info:
"Why can't I use 4x4 mode all the time or on the roads?
There's drive to both axles and the front and rear axles have different turning circles. On hard/dry surfaces like tarmac there's no give on the road surface so you'll end up with windup on the transmission which can destroy it.
Permanent 4WD vehicles like Range Rovers have a differential in the transfer case to allow it to slip as you turn in circles. The Surf is not intended as a permanent 4WD vehicle."
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 244 000 KM
Sidney is offline
Old 06-21-2005, 06:45 AM   #8 (permalink)
rogerman's Avatar
oh shit yeah thanks for the imput guys so im not alone man thank god for toyota 4wd saved my ass so many times
rogerman is offline
Old 06-21-2005, 09:06 AM   #9 (permalink)
What country are you from? I cannot recognize M.P.
Sidney® ™
Canada
for I am
Sidney is offline
Old 06-22-2005, 07:02 AM   #10 (permalink)
rogerman's Avatar
lol i live on a Island In the Nothern Pacific called Saipan which is near the Island of Guam if that still doesnt ring a bell im south of Hawaii and near Japan and Korea. Saipan is a Commonwealth of the U.S.
rogerman is offline
Old 06-22-2005, 09:05 AM   #11 (permalink)
Hi I just looked you up on the globe and you are near Palau where the last reality tv show "Survivor" took place,lucky you.If I ever want to take a vacation can I come and visit you?.
Sidney® ™
Canada
for I am
Sidney is offline
Old 06-23-2005, 07:33 AM   #12 (permalink)
rogerman's Avatar
hahaha your better off going to Palau its much more prestine and great for diving and its cheap.
rogerman is offline
