Crank seal replacement 3.0 3VZE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2005, 10:03 AM   #1 (permalink)
View Glynn's Photo Gallery
I just received a Timing Belt replacement kit for my 1990 3.0 3VZE. The main reason for doing this job is to replace the crank seal, which is leaking a bunch. The instructions for removing the crankshaft pulley requires the use of a counter-holding bar to be used when removing and installing the crankshaft bolt.
Is a counter-holding bar a readily available tool from autopart stores or can a bar be easily improvised?
Thanks for your input.
Glynn is offline
Old 07-03-2005, 07:47 PM   #2 (permalink)
View rlbrobst's Photo Gallery
Glynn,
I had the same problem but instead opted to use an impact wrench. It broke the nut free no problem.
rlbrobst is offline
Old 07-05-2005, 12:20 PM   #3 (permalink)
I started the job Saturday, with the help of a mechanically inclined friend. He tried an impact wrench for a little while with no success and then used a long tapered bar to wedge inside the pulley and leveraged it against the socket. It finally broke free. That's a nice sized bolt holding the crankshaft pulley on.
We discovered that the ac compressor v-belt also needed replacing so I'll have to finish the project later this week.
Glynn is offline
