You definetly blew your headgasket usually due to either a stuck closed stat or using aftermarket green Prestone or similar radiator coolant anti-freeze which is high in silicates that commonly promotes corrosion buildup in the tiny water bypass ports/jackets in the aluminum cylinder head and thereby blowing the head gasket more than likely around cylinder # 1 & 4.
You need to resurface your cylinder head as more than likely it's warped which can be verified by setting it on a flat kitchen top counter then you would have to advance your engine base timing by 1 degree to compensate for every 1/1000" th (of an inch) of resurfacing I believe.
To verify my claims do a leak down test and a fluid analysis kit which is available at any Caterpillar dealer around the world or at your local heavy duty mechanic shops that commonly repair bulldozers,backhoes,big rigs and the like.
I would suggest that you quickly drain your old oil before the coolant DESTROYS YOUR CRANKSHAFT BEARINGS thereby making one of the most reliable engines ever made become useless.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 244 000 KM
for I am
