new crank seal ... still leaking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2005, 10:34 PM   #1 (permalink)
Stop buying garbage
peterng's Avatar
View peterng's Photo Gallery
Canada new crank seal ... still leaking
Eh,
So I put a new front crank seal in my 89 22re last winter when I did the timing chain guide job. The bottom front of the engine is pretty wet these days and it looks like it is coming from the crank. I searched the forums and saw the belknap/Napa sleeve solution but I wasnt able to find very much information about it on the internet.
Anyone done this or have any input on this issue?
ps. the crank itself around the area where the seal went looked great to the eye ... is there any other reason it could be leaking?
Thanks,
Pete
http://members.localnet.com/~mkcooper
peterng is offline
Old 06-26-2005, 07:36 AM   #2 (permalink)
View qsd-dan's Photo Gallery
Here is one thread that I could dig up. Might be worth putting in "22re crankshaf seal" or " 22re front main seal" in google and see what comes up.
http://yotatech.com/showthread.php?t...ght=crank+seal
qsd-dan is offline
Old 06-26-2005, 07:38 AM   #3 (permalink)
View Sidney's Photo Gallery
The front crankshaft oil seal usually lasts 140-170 000 miles and the info is below:
Harmonic balancer repair sleeve/speedy sleeve (seal saver sleeve,balancer repair sleeve,crank seal saver) slides over shaft:
Felpro # 16214=$5
Future # 21-2514 (aluminum shaft sleeve included)
NAPA repair sleeve # 99177 (Mack PDC,National,Car Quest)
Pioneer repair sleeve (Silver Seal) # HB-4133
attached with some epoxy or use Loctite 609 or 242 or put some red RTV and fill that groove before you put it on also look in the yellow pages under “bearing suppliers”.
For a picture:
http://www.chicago-rawhide.com/auto/speedi/speedi.htm
Front crank oil seal (front input shaft seal):
Fed Mogul (National,Timken Seals) # 710345
Toyota # 90311-45014 (brown, 7 mm thick) & 90311-30115, Chicago Rawhide # CR17758 (9 mm thick) or CR550294 (7mm thick)
Beck Arnley # 0522144
NAPA repair sleeve # 99317(rear),list price $68.10>$33.19 net Canadian $
and the seal was $12.10
Rear crank seal Toyota # 90311-80010,90311-80001 (the earlier 20R & 22R seal),90311-80010 (is the improved version. It is made out of silicone and has double lip for better sealing).
This info provided by EB:there are 3 versions of the speedy sleeve:
1)one is light steel with spray chrome flashing(yuk)
2)one is steel with chrome plating
3)and the good ones are all stainless steel and they are made in Canada.
http://www.barneymc.com/toy_root/techneek/frntseal.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 244 000 KM
for I am
Sidney is offline
