cold start issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 09:56 AM   #1 (permalink)
View smasheromalley's Photo Gallery
cold start issue
Ive got some sort of cold start problem on my 87 pickup.
If I try to jump in and turn the key it will have to crank for several seconds before the engine spits and sputters to life, then eventually will run normally...
But if I get in crank the engine for 1 second or less (not expecting it to start) then go to key off and THEN go to start then engine it will fire up like a champ and run normally.
So far the only thing Ive been able to find is somebody telling me something about a cold start injector. ANybody have any info on this of row it works?
Thanks
smasheromalley is offline
Old 06-27-2005, 07:59 PM   #2 (permalink)
Dads toy
Hermit's Avatar
View Hermit's Photo Gallery
What engine? 4 cyl-6cyl? Fuel injection or carb? You also stated that it eventually runs normal. Does it run really shitty for a while when you first start it cold? Does it only happen with a cold start condition?
Post some stats and I will see if I can come up with any tips or answers. I'll pick my ole brain a bit. I'm sure we can come up with some suggestions.
*HERMIT* the T-Tech
"OH WHAT-A-FEELIN"
Hermit is offline
Old 06-27-2005, 10:29 PM   #3 (permalink)
I updated my sig with the truck info...
If I let it soak for 6-8 hours and jump in a start on the first key cycle it would probably take 7-10 seconds total to run just fine.
If I do my key cycle trick before starting it runs perfect from the go.
^^^ Im having a hard time not making this sound confusing
'87 1ton dually C/C
injected 22-RE 4-speed 4x2
Old 06-28-2005, 11:33 AM   #4 (permalink)
Dads toy
Hermit's Avatar
Cool
EFI or Carb?
*HERMIT* the T-Tech
"OH WHAT-A-FEELIN"
Hermit is offline
Old 06-28-2005, 01:25 PM   #5 (permalink)
OMG sorry... I typed a whole long reply with the info but lost it when I accidentally hit the stupid google search link right above the quick reply box
Its EFI
'87 1ton dually C/C
Old 06-29-2005, 12:26 AM   #6 (permalink)
Dads toy
Hermit's Avatar
I have seen worn plugs cause this condition as well as a dirty fuel filt.
Another thing to check would be the priming curcuit which is your cold start injector and the cold start injector timing switch.
To check the cold start injector the engine must be cold. Start the engine and listen to the cold start injector located on the air intake chamber. you should hear a clicking noise which means the injector is working. After the truck reaches normal operating temp the clicking should stop.
I hope some of this helps you out!
*HERMIT* the T-Tech
"OH WHAT-A-FEELIN"
91 yota 4x4 DLX v6 x-cab Many mods soooon to come!!
Hermit is offline
