You Know the Noise... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2005, 11:48 PM   #1 (permalink)
View Saabeh's Photo Gallery
That your truck makes when you make a sharp slow turn. A loud bang that is metallic. What is it and how do I fix it. I remember hearing that alot of people have this. My old truck had it but it had smaller tires. Thanks.
Saabeh is offline
Old 07-03-2005, 10:25 AM   #2 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
Probably your tires rubbing on the steering stops.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 07-03-2005, 01:17 PM   #3 (permalink)
View black93DX's Photo Gallery
Its your bumpstops. Grease them up with a little bearing grease and they'll be fine.
93 DX Ext. Cab.- 5 speed,FM40,K&N,31x11.50 RVT's
black93DX is offline
Old 07-03-2005, 01:42 PM   #4 (permalink)
Dads toy
Hermit's Avatar
View Hermit's Photo Gallery
The cap'n is right. On the right and left front wheels you have 4 steering/wheel stops. 2 for each wheel. There are stop pans Located on the lower control arms and posts located on the lower portion of the spindles. These prevent excessive travel of your front wheels and tires while making very sharp turns. Ya know..the kind you make when your turning around, 4 wheelin or doing slow tight manuvers(turns).
The posts have plastic caps on them which eventually over time split and fall off leaving a bare, rusted end exposed. When making your sharp turn the dry post makes contact with the dry rust on the pan and it makes a loud metallic popping noise as they pinch together. It can be pretty loud at times.
The caps are cheap to buy at any local dealer and just snap on.Untill you get them replaced just cleaning this area and adding some grease or anti-seize will get rid of the noise. I would definitely replace the caps otherwise the noise will return over and over again. Just be sure to grease the new caps when you install them.
Hope this helps!
*HERMIT* the T-TECH
"OH WHAT-A-FEELIN"
Hermit is offline
Old 07-03-2005, 03:44 PM   #5 (permalink)
Toyota Fanboy
Bakemono's Avatar
Yup, my '91 4Runner made that noise! The cure I found for the problem was not turning the wheel to full-lock!
Cap'n
'07 Toyota Camry LE
Bakemono is offline
Old 07-03-2005, 08:39 PM   #6 (permalink)
View rlbrobst's Photo Gallery
Yeh, my 91 ext cab had the same noise. I found some rubber caps at the local bearing house, the kind that go on top of the threads of a air cylinder, and put them on and it did not make the noise any longer. Another solution a friend of mine used was to sand the rusy part and get some black rtv and put a dab on it and let it set up before driving. It quieted his down.
rlbrobst is offline
Old 07-04-2005, 01:11 PM   #7 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
my 92' does this same noise on hard left turns only. Im not exactly 100% sure what you guys are talking about with the stops. If you could post a pic, or something of where the stop is, id appreciate it. (need to fix this problem , its driving me up the wall)
thanks, -Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
