85 22RE running #1 & 3- Test=code6 RPM HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2005, 12:07 PM   #1 (permalink)
View Greenbush's Photo Gallery
Angry 85 22RE running #1 & 3- Test=code6 RPM HELP
HELP!! #2 & #4 not workin.
I have a 85 EFI 4x4 that is running mr ragged.
I have replaced the rotor, cap, wires and fuel filter. I get a spark at the end of the plug wire yet no ignition.
When I tested the computer it blinked 6 times= RPM System- ignitor assembly, ignitor, injector, Distributor or ECU.
- Now if it was an injector problem then why does the two on the same circuit go out?
- If it is the ignitor assembly in the Distributor then again why opposing cylinders?
I hope it is not either the Ignitor($260) or the ECU($400). Anyone have any ideas??????????
Greenbush is offline
Old 07-07-2005, 12:47 PM   #2 (permalink)
View david in germany's Photo Gallery
it is the fuel injector wires 1&3 are wired together and 2&4 are together. get some time, a new gasket for the intake and some Etape and soem Heatshrink tubeing and about 30-45 min and you can fix it. I found my broken wire not quite underneeth the intake so I didn't need to remove the upper half to do mine (wish I knew that befor I did it)
I am in my own little world but it's ok they know me here!
david in germany is offline
Old 07-22-2005, 04:14 PM   #3 (permalink)
Fixed It Thanks
Fixed it Thanks. A short.
