From the front of your truck, looking under the hood, the temp sender is located below and to the right of the TPS (throttle body). There should be 2 sensors . The one on the right is a vac switch (should have air hoses attached) and the other will be the temp sender. They point out toward the front of the truck.
I do not think there is a sensor and a sending unit, they should be one in the same.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
