it's an auto, right? i don;t know exactly how the shifter is on your truck, or any auto, but if there is a large button on it (that does not say overdrive) hold that in while trying. (im thinking of the shifter in most avaons and camry's) also it may just be a saftey feature toyota put in there to prevent parked cars from rolling away, like if a little kid was playing with the shifter and popped it into neutral while the car was off. if you can't move the car, see if one of your neighbors has a portable battery charger that you could hook up, or you could switch the battery out of another car just to move yours. good luck
