Length of brake lines for 85 4-Runner (4x4) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2005, 08:36 PM   #1 (permalink)
View Sidney's Photo Gallery
Canada Length of brake lines for 85 4-Runner (4x4)
I need the length of brake lines & UAP/NAPA & Canadian Tire part #'s for my 85 4-Runner (4x4) for the following:
A)the two long brake lines running on the passenger side frame rail along side the gasoline lines going from the front passenger tire area frame all the way back to the load sensing valve (overload proportional valve).
Top line Toyota part # 47315-35060
Bottom line Toyota part # 47322-35290
B)the two brake lines going from the front passenger tire area frame two the master brake cylinder.
Top line Toyota part # 47321-35280
Bottom line Toyota part # 47312-35540
C)The union adapter that connects the two above lines together at the front passenger frame rail near the tire.
Toyota part # 90415-10006
D)The union adapter that connects the front driver's side caliper line to the master cylinder.
Toyota part # 90413-10111
E)The front passenger side frame brake line going from the union adapter to the rubber hose which leads to the front passenger caliper.
Toyota part # 47314-35190
E)The front driver's side frame brake line going from the union adapter connected to the master brake cylinder going to the rubber hose which leads to the front driver's side caliper.
Toyota part # 47313-35320
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM
Sidney is offline
Old 07-21-2005, 11:06 AM   #2 (permalink)
What is the size of steel brake line that I need to buy from UAP/NAPA? and what are the sizes of the fittings that I need to purchase for all 6 brake lines? so that my friend can use his flaring tool.Thanks.
Sidney® ™
Canada
Sidney is offline
Old 07-28-2005, 08:25 PM   #3 (permalink)
Before I replaced the lines I kept pressing the brake pedal in hopes that I would have some brakes left so I can drive home but apperently I run the brake master cylinder dry.I pumped the brakes about 10 times along the drive and now after replacing the 6 brake lines I bled the front & rear wheels many times (I got lots of fluid coming out but no air) but I still don't have brakes.Could I have destroyed the master cylinder?.Thanks.
Sidney® ™
Canada
Sidney is offline
