ive heard that most shops wont flush them with over 100k on them. Too much of a liability of a weak part snapping off during the flush i guess. Your best bet is to drain it, drop the pan, and buy a new automatic transmission filter and install it yourself. Its not hard. The filter obviously traps the gunk out of the internals of the trans. When you drop the pan, itll be right there, so its not hard to do. Buy a kit with the filter and gasket for the pan. Torque the bolts down evenly to avoid leaks, and refill. Its not a flush because it wont get all old fluid out, but will be like an oil change with a filter.
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
