tricks for getting stuck rotors off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2005, 10:16 AM   #1 (permalink)
View dklink2000's Photo Gallery
Does anyone have any tricks for getting a hopelessly stuck from brake rotor off of a '01 tacoma prerunner?
dklink2000 is offline
Old 07-26-2005, 02:43 PM   #2 (permalink)
orange brick
80toy's Avatar
View 80toy's Photo Gallery
what have you tried so far? is rust involved? check all connections, nuts, calipers, etc. have you tried WD-40 and a rubber mallet?
80toy is offline
Old 07-26-2005, 03:38 PM   #3 (permalink)
Gameroom cash: $133655
slide hammer maybe....... or some sort of puller
try spraying PB Blaster where it's rusted on and letting it sit for 10 min or so then try again
toyotaspeed90 is offline
Old 07-27-2005, 05:43 AM   #4 (permalink)
View tr918's Photo Gallery
First check to see if the rotor is attached to the hub. Some models have the rotors bolted to the back side of the hub. You have to remove the hub and then remove the rotor from the hub.
If it is not attached to the hub any type of puller that is large enough to grab the outside of the rotor will work. Spray it good with wd-40 or other rust loosening lubricant. If you are NOT planning on saving the rotor, give it a couple of good whacks with a ball peen hammer.
good luck
tr918 is offline
Old 07-27-2005, 06:46 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Is that a 4x4?
雄のハヤブサ
Tercel GTS is offline
Old 07-27-2005, 07:54 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
if your replacing the rotor...SLEDGEHAMMER...otherwise a sidehammer and PB blaster
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline
Old 07-27-2005, 08:03 AM   #7 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
pb plaster and light it on fire, it sounds crazy but it worked for me after its lit and burns down hit it whit a hammer on the outer edges a little bit all the way arround
ekim55121 is offline
Old 07-28-2005, 01:14 PM   #8 (permalink)
Moving Forward
View Cyorke's Photo Gallery
spray it down really good with whatever penetrating oil you want. Usually on Toyotas they have two holes in th face of the rotor that you can run bolts into to basically puch the rotor off. JUst go slow so you dont damge the rotor.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline
