Clutch pedal noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2005, 09:24 AM   #1 (permalink)
View grisgris's Photo Gallery
Clutch pedal noise
Hi,
I've got a 98 4Runner, 4 cylinder, manual transmission. 100k miles. The clutch pedal makes a funny noise, like a screen door spring. It also is a little mushy at the top end, doesn't just pop back up.
No transmission noise, chatter or problems shifting. Plenty of fluid in the master cylinder reservoir. No lateral play on the pedal itself. The pushrod going through the firewall has a little play.
I presume a bearing or bushing is gone in the spring area.
Any suggestions?
TIA
Lee
grisgris is offline
Old 08-01-2005, 04:44 PM   #2 (permalink)
View toysports2k's Photo Gallery
take a look at the clutch pedal mounting bracket, in particular where the bracket is attached to the firewall. there are some spot welds that can break loose and cause the problems you're describing. it's a pain in the arse to get up under there, but i was able to fix the problem in no time with my little wire-feed welder.
'93 RN80; LCE 22RE 2.6L, K&N Intake, LCE modified TB, Crane Cam ignition, LCE header, exhaust and hi-flow cat, 4-linked and bagged by Can-Do Specialties
toysports2k is offline
Old 08-01-2005, 09:50 PM   #3 (permalink)
Street Racer
View BlkSrx's Photo Gallery
Was it really cold outside? My truck make the same noise, during the winter times.
BlkSrx is offline
