4 wd 1986 lack of power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2005, 06:03 PM   #1 (permalink)
View paultio's Photo Gallery
I have 86 toyota 4 wd I did the tune up myself by replacing the plug,air filter check the ignition timing and replace the pvc and fuel filter but It still seem to lack inpower wonder what happened here The idle speed is around 600 rpm and the dwell angle is 12 degree
I am planning to check the EGR maybe? Please Help thanks
paultio is offline
Old 08-02-2005, 07:47 PM   #2 (permalink)
View GregoryM's Photo Gallery
"dwell angle"??? Your engine has electronic ignition. Dwell is a reference to contact point adjustment. Initial timing should be set with the vacuum advance plugged. Are you sure of your adjustments?
GregoryM is offline
Old 08-02-2005, 11:17 PM   #3 (permalink)
TOYO-MAN
View sonofmayhem's Photo Gallery
make sure your mass air flow sensor is connected all of the way, and your air box lid. i have an idle adjustment screw right by my throttle body that if you turn it it changes the rpms
85, lifted and ready to rock!
sonofmayhem is offline
Old 08-05-2005, 04:17 PM   #4 (permalink)
Sorry it should be BTDC angle and not dwell angle
paultio is offline
Old 08-05-2005, 04:18 PM   #5 (permalink)
wher is the air flow sensor located and Why it will affect the engine performance
Thanks
paultio is offline
Old 08-06-2005, 03:51 PM   #6 (permalink)
reb
View reb's Photo Gallery
Is your engine a 22R or 22RE? The air flow sensor is part of the fuel injection system, which the 22R does not have.
reb is offline
