'87 22re EFS Puzzle... wanna play?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2005, 10:54 PM   #1 (permalink)
View Toyota Tough's Photo Gallery
Unhappy '87 22re EFS Puzzle... wanna play??
Hey guys, I just joined but I've gained plenty of info browsing through here for the past nine months. Now I've found a problem I haven't been able to answer... so I need advice. Anyone who helps gets their name engraved on the inside of my brake rotors...
I have an '87 Longbed 4x4, 216k mile and still running strong - I've had it for nine months with a valid inspection sticker, I just tried to renew it and it failed the smog test - running rich. I ran the codes from the ECU and it was showing "Throttle Position Sensor".
I tested the sensor and the readings were way off... so I replaced it with a new one. I turned the key, cranked the engine, and it it immediately climbed to about 7k and cut out... climbed to 7k and cut out. It just kept racing high, cutting out, catching and racing high again. WTF??
So, I throw the old TPS back on and it is doing the same thing. I go to the boneyard, pull a working ECU, swap it in, and no help.
I am stumped. My next thought was to pull and clean the TB, replace the injectors... and if that doesn't work, bang my head on the valve cover until I can't remember that it doesn't run properly...
Any ideas? Thanks in advance.
Toyota Tough is offline
Old 08-08-2005, 12:48 AM   #2 (permalink)
SovereignScorn's Avatar
View SovereignScorn's Photo Gallery
This is going to sound horrible, but I had a similar problem with my lawnmower. The problem ended up being a twig jammed in the throttle. I dont know alot, but it sounds like your problem might have something to do with the throttle cable, or possibly the spring on your gas petal.
SovereignScorn is offline
Old 08-13-2005, 02:04 AM   #3 (permalink)
View qsd-dan's Photo Gallery
When you installed the new TPS sensor, did you go through the proper procedures of adjusting it? Here is a website that takes you through the steps.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
qsd-dan is offline
Old 08-13-2005, 07:16 AM   #4 (permalink)
View Sidney's Photo Gallery
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiB...pair_guide.jsp
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
http://www.showmesome.info/hilux/info/manuals/1KZ-TE
http://surf.mactherapy.com/1KZ-TE.pdf
http://surf.mactherapy.com/parts/
http://www.spyderchat.com/1zzfe.pdf
http://files.matrixvibe.net/docs/1zzfe.pdf
http://landcruiser.free.fr/mans/
http://www.turbosupras.com/pages/technical/tsrm.htm
http://www.lieblweb.com/tacoma/Mecha...rams/index.htm
http://perso.wanadoo.fr/adherence.4x...techniques.htm
http://perso.wanadoo.fr/adherence.4x4/index.htm
http://www.asatraction4x4.cl/html/
http://www.toyotasurf.asn.au/techsite/downloads.htm
http://www.grubinski.com/grubinski/a...oyota.manuals/
http://www.carsoft.ru/files/4runner95di.exe
http://www.hotrodder.com/kwkride/tech.html
http://www.autoshop101.com/autoshop15.html
http://www.mtv411.com/sitemap.htm
http://www.toyota.com.my/index.asp?f...article&aid=40
1985 Toyota 4-Runner/pickup Factory Service manual:
http://www.jasuza.com/1985toyotatruckfsm.pdf
1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
2003 (2001-2004) Toyota Tacoma Factory Service Manual:
http://fsm.afraid.org/
http://www.junglecode.com/toyota/tacoma/2003_fsm/
http://65.200.1.6/FSM/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM
for I am
Sidney is offline
Old 08-13-2005, 01:09 PM   #5 (permalink)
Toyota Fanboy
Bakemono's Avatar
View Bakemono's Photo Gallery
Definetely sounds like your TPS isnt sensing the throttle position correctly. It almost sounds like the TPS is pumping as much fuel as possible into the engine, which causes it to rev that high.
Cap'n
Originally Posted by Vmax2007 View Post
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Bakemono is offline
Old 08-13-2005, 04:23 PM   #6 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Definitely sounds like it just needs proper adjustment. If it was mis-adjusted before and proper adjusted now, you will need to adjust the idle speed screw to bring down the RPM's. It is the screw located on top of the throttle body chamber.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
