i had messed with my sensor a while back and didnt fully understand what i was doing and caused many problems. i was puting an intake on and just honestly knew nothing and cut open the seal and messed with it....bad idea. but anyway, why do you want to clean it? it wouldnt do much for it and it will be hard to reassemble. i had to get one from a yard and make sure the nuumbers matched and it was a big deal. i talked to toyota and they said that you should never break that silicone seal cause if any water gets in it can be a problem. better off just taking it off and cleaning it from the little door on the side and put it back on instead of taking it apart to clean it.
