"Check engine" light on Sequioa - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 09:40 PM   #1 (permalink)
View Ripe911's Photo Gallery
Hello everyone, I had my 2001 Sequioa for 2 months now. Has about 46k miles on it. Just last week the check engine light came on but I did not find anything different in the way the truck drives.
Toyota Service diagnosed the problem and said that I needed to replace the canister valve assembly and switch. Can anyone tell me what this is ? what this does? and how can I prevent this from going bad again? Thanks.
Ripe911 is offline
Old 08-14-2005, 01:22 AM   #2 (permalink)
cam2Xrunner's Avatar
Did you happen to get the code number it read? Did they say it was the Charcoal Canister.
Do you happen to be a member of www.tundrasolutions.com ? If you are let me know, and I'll show you a few links regarding the subject.
If you aren't I would highly suggest you register over there(free) There's alot of good info there.
Also Welcome to TN
cam2Xrunner is offline
Old 08-16-2005, 04:46 PM   #3 (permalink)
View ffpmlex's Photo Gallery
Without getting a better description, I'd agree that it sounds like a charcoal canister problem. It could be cracked, the hoses connected to it could be cracked or loose, or most commonly, the check valves are stuck or clogged. I am not too familiar with how your model SUV is designed, but you usually have to buy the entire assembly and cannot replace the check valves just by themselves.
Lift uo the hood and start your engine. Is there a stronger than usual smell of fuel? If so, first check all the hoses leading to the charcoal canister before you go replacing it. The charcoal canister is part of a system that collects fuel that evaporates from your fuel tank so that it doesn't get released into the atmosphere. Unfortunately, if you live in a warm climate, your fuel is more prone to quicker evaporation. Eventually, the pores in the charcoal of the canister will fill up and it will have to be replaced...nothing you can really do about that. If the vehicle was not driven for an extended time(like one month), all that fuel evaporates a lot quicker into the charcoal canister. Yet another reason to start up your vehicle every few days!
ffpmlex is offline
