'90 p/u power loss @speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2005, 11:10 PM   #1 (permalink)
View PhilYoters's Photo Gallery
Unhappy '90 p/u power loss @speed
I have a '90 3.0L p/u that has massive power loss while
@ speed. It only happens early morning/ late nite after sitting for many hours. Usually I first drive around noon and go home round 2AM. During day it's fine. Freeway 4th and 5th cut out around 65mph, gears NOT slipping just complete loss, sometimes for 10-15 secs then jolts back...continuous. If I put into Neutral during loss, engine dies then pop clutch in 4th and resume problem. Recent new clutch, partial trans rebuild, and catalytic converter. Truck @ dealer now but doesn't look good. CAN SOMEONE PLEASE HELP?!! This seems to surpass my knowledge and I don't want to do guessing replacements.
PhilYoters is offline
Old 08-16-2005, 12:32 AM   #2 (permalink)
View JSchad2000's Photo Gallery
Do you know haw to pull the Codes to diagnose the problem? If you look at the reply to my post form 8-13-05 at 10:16 JSchad2000 from Sidney, there are urls to several sights that explain the codes and how to jumper the terminals to read the codes. I haven't run the codes on mine yet because its in the shop for a cooloant leak at the intake manifold, but when I get it back I plan to find out why mine does the same thing, except I don't have a manual trans.
JSchad2000 is offline
Old 08-16-2005, 04:57 PM   #3 (permalink)
Well dealer "thinks" maybe bad head gasket but I told him no guess work, especially for what he wants to charge. Going to give him suggestion of compression test and mention the idea of checking codes.
Old 08-21-2005, 04:27 PM   #4 (permalink)
Ok the dealer found the problem except the part is on national backorder and could take a month or more. I told the mech to check out all the ECU codes and they came up with a faulty SPEED SENSOR. That should be fairly easy to replace w/o much needed knowledge. the sensor was telling engine that it was going 140 when it was really like 70, therefore confusing the ECU and screwing up the air fuel mix and causing the power drop.
Old 08-21-2005, 07:57 PM   #5 (permalink)
Maybe you can find the part on the internet, just because Toyota doesn't have it, doesn't mean its not available. You might try to Google Toyota speed sensor.
I'm glad you you able to find your problem, my mechanic pulled my codes, but there were no error codes.
Old 08-21-2005, 08:39 PM   #6 (permalink)
View Sidney's Photo Gallery
Phil to look up complete USA inventory of dealerships including Toyota:
http://www.worldparts.com/auto
http://www.partsvoice.com/
These Toyota online dealerships have the best prices in the USA (30% off retail) & probably the whole world:
http://www.1sttoyotaparts.com/partscat.html (10% shipping by Fed Ex or free shipping with $100 & over speak to Roger at 1-888-271-3948
http://www.Toyotaparts4U.com
http://www.toyotaofplano.com
more than likely if you type in the Toyota part # at the above links you will find one in stock,I never heard of any part being on national back order for 1 month,I think your mechanics licence or certificate your be backordered for life.
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM
O
|\ __O
_|_| \
Sidney is offline
Old 08-21-2005, 08:44 PM   #7 (permalink)
Like I stated in my earlier replies regarding pulling the ECU codes if no codes are found you then:
Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio.
Sidney® ™
Canada
http://www.iwaynet.net/~nesda/May02/May18.html
http://www.iwaynet.net/~nesda/SonyAudMod.html
http://www.newark.com/product-detail...ge/32-9495.jpg
http://www.iwaynet.net/~nesda/Oct02/Oct028.html
http://www.iwaynet.net/~nesda/Oct02/Oct029.html
http://www.iwaynet.net/~nesda/Oct04/Oct041.html
O
|\ __O
_|_| \
Sidney is offline
Old 08-21-2005, 08:50 PM   #8 (permalink)
These are 38 Toyota used parts suppliers and junk/bone/wrecking/salvage/recycling/dismantling/scrap yards:
Toy Works 4WD Technology
Shane Lawrence
County Road 109
Orangeville,Ontario L9V 1A1
Canada
Ph: (519) 938-9844
Toy Works
K C Signs
Portugal Cove,NL A0A 3K0
Canada
Ph: (709) 895-6123
South Island Imports
2053 Balsam Rd
Nanaimo (South),Vancouver Island,BC V9X 1T5
Canada
Ph: 1-877-753-1119
Ph: (250) 753-8019
http://www.southislandimports.ca
E-mail:southislandimports@shaw.ca
Toyota 4x4 center (AllToy)
Kami 4X4
Tony Carr
427 Mount Paul Way
South Kamloops,BC V2H 1A7
Canada
Ph: (250) 851-4480
Precision 4X4 Center (www.*********************) (some pickup diesel parts)
Corey Maidment (slacker)
1280 Commercial Way Unit 109
Penticton,BC V2A 3H5
Canada
Ph: (250) 493-9473
Fax: (250) 493-9474
http://www.*********************
http://www.geocities.com/motorcity/flats/1738
info@*********************
support@*********************
sales@*********************
Corey CJ@*********************
webmaster@*********************
slacker501@shaw.ca
coreymaidment@netscape.net
HonDaToy Automotive Ltd
14325-114 Ave
Edmonton,Alberta T5M 2Y8
Canada
Ph: 1-800-661-3957
Ph: (780) 453-6711
http://www.hondatoy.com
E-mail:parts@hondatoy.com
Adamant Service Center
Box 70,Hagget Rd
Adamant,VT 05640
USA
Ph: (802) 233-1488
E-mail:asc@drbs.com
Woodward's Used Toyota Parts
3059 Main St
PO Box 236
Summneytown,PA 18084
USA
Ph: 1-800-646-4386
Ph: (215) 234-4386
Fax: (215) 234-8035
Lowells Toyota Parts
111 Mechanic St
Lexington,KY 40507
USA
Ph: (606) 233-1173
Tallant Brothers (Toyota/Honda/Nissan)
Jimmy & Greg
4695 Oak Grove Circle
Cumming,GA 30130
USA
Ph: 1-800-635-0351
Ph: (404) 887-5214
Fax: (770) 889-7244
Graham's Automotive
958 HWY 202
Calera,AL 35040
USA
Ph: (205) 668-3441
http://www.grahamsauto.com
E-mail:jon@grahamsauto.com
Victor's Off Road Engineering
Victor
4646 Lonedell Road
Arnold (Saint Louis),Missouri 63010
USA
Ph: (636)296-6696
Toyota Heaven
6723 Oakcrest Dr East
Fort Worth/Kennedale,TX 76140
USA
Ph: (817) 563-1744
Ph: (817) 563-1754
E-mail:frs@toyohv.actual-america.com
A-1 Toyota Salvage
302 New Laredo Highway
San Antonio,TX 78211-1908
USA
Ph: (210) 921-0031
Yota Yard
Jim/Nancy Wales
3134 Walnut St
Denver,CO 80205
USA
Ph: (303) 292-5078
Fax: (303) 308-0430
http://www.yotayard.com
E-mail:nancy@yotayard.com
Toyotas "R" Us
7730 CR 150
Salida,CO 81201
USA
Ph: (719) 539-7733
Toyota Salvage
3224 S 40th St
Phoenix,Arizona 85040
USA
Ph: 1-877-807-4314
Ph: (602) 437-1222
http://www.toyotasalvage.com
Mazda-Toyota Auto Recycling (also Nissan)
Richard
3611 NW Marine Dr
Troutdale,OR 97060
USA
Ph: 1-800-628-0918
Ph: (503) 667-6818
Fax: (503) 669-7810
http://www.maztoy.com/
E-mail:sales@maztoy.com
The Toyota Man
3610 NE Columbia Blvd
Portland,OR 97211
USA
Ph: (503) 775-3345
E-mail:thetoyotaman@earthlink.net
Nix 99
13718 Mukilteo Speedway
Lynnwood,WA 98037
USA
Ph: 1-800-782-0682
Ph: (425) 743-2881
http://www.nix99.com
E-mail:parts@nix99.com
All Toyota Auto Recycling
27865 SR 410
East Buckley,WA 98321
USA
Ph: 1-800-829-9766
Fax: (360) 829-1852
E-mail:dliy@aol.com
Kings Honda & Toyota Auto Recycling Inc
9101 Martin Luther King Jr.Way South
Seattle,WA 98118
USA
Ph: (206) 723-9633
Fax: (206) 722-1599
http://www.kingshondaandtoyota.com
E-mail:parts@KingsHondaAndToyota.com
All Japanese Auto Recyclers
11301 Dismantle CT
Rancho Cordova,CA 95742
USA
Ph: 1-888-608-PART
Ph: (916) 635-2345
Fax: (916) 635-8100
http://www.alljapaneseautoparts.com
E-mail:alljapanese@jps.net
Toyota Truck & Auto Recycling (TAP Recycling)
11337 Dismantle CT
USA
Ph: (916) 631-7100
Toyota Engines By CT Engineering
3457 Fitzgerald Rd
USA
Ph: (916) 852-1032
All Toyota Used Parts
3370-A Sunrise Blvd
USA
Ph: 1-800-557-8674
Ph: (916) 853-7242
Fax: (916) 635-5724
http://www.alltoyotausedparts.com/
E-mail:webmaster@alltoyotausedparts.com
Al
3636 Omac Circle
USA
Ph: 1-800-765-7100
Toyota Truck Parts
3440 Recycle Road
Sacramento,CA 95742
USA
Ph: 1-866-292-9495
Ph: (916) 853-0833
http://www.toyotatruckparts.biz/
E-mail:service@toyotatruckparts.biz
Capitol Import
4071 Happy Lane
Sacramento,CA 95827
USA
Ph: 1-800-259-5529
Ph: (916) 366-7470
http://www.capitolimport.com
E-mail:sales@capitolimport.com
The Toyota Connection
Ryan
2620 W. Capital Ave
West Sacramento,CA 95691
USA
Ph: 1-800-221-8696
Ph: (916) 371-7764
Fax: (916) 371-7037
Toyotas Only
11540 Hart St
N. Hollywood,CA 91604/5
USA
Ph: 1-800-835-2444
Ph: (818) 765-0322
Ph: (818) 765-0323
Fax: (818) 765-8013
http://www.toyopartsonly.com
E-mail:webmaster@toyopartsonly.com
LA Toyota Auto Dismantling Inc
11115 Tuxford ST
Sun Valley,CA 91352
USA
Ph: (818) 768 4142
Fax: (818) 768 8442
D & T Used Parts/DNT Auto Dismantling (Datsuns and Toyotas)
8970 Bradley Ave
Sun Valley,CA 91352 or Pacoima,CA 91331
USA
Ph: (818) 768-4666
Toyota Truck & 4X4 Dismantlers
991 Berryessa Road
San Jose,CA 95133
USA
Ph: (408) 436-7890
Fax: (408) 436-9779
Bernie's Auto Dismantling
1008 Vreeland Ave
Wilmington,CA 90744
USA
Ph: (310) 518-2685
California Mini-Truck Dismantlers
4002 State Street
Montclair,CA 91765
USA
Ph: (909) 622-1381
Fax: (909) 623-3240
http://www.calminitruck.com/
E-mail:info@calminitruck.com
Minit Truck Dismantling Center
1700 Newton Avenue
San Diego,CA 92113
USA
Ph: 1-800-827-1970
Ph: (619) 233-3884
All Toyota Lexus Auto Recycling
Chuck
1060 Otay Valley Rd
San Diego,CA 92154-5615
USA
Ph: 1-877-778-6968
Ph: (619) 661-0055
E-Mail:scrapdaddy@cox.net
Here are 39 other 4-Runner/pickup discussion sites which have free classifieds:
http://www.wildyoats.com/vbulletin
http://www.yotatech.com/index.php
http://www.off-road.com/toyota
http://www.toyota-4runner.org
http://www.toyotaoffroad.com
http://mkelly.proboards22.com
http://www.t4x4pickup.com/dgroup/index.html
http://www.voy.com/83795/
http://www.4x4wire.com/toyota
http://forum.ih8mud.com
http://board.marlincrawler.com/index...0db2fa424afcf&
http://www.birfield.com/modules.php?name=Forums
[url]http://www.pavementsucks.com/forums/viewforum.php?forum=14
http://www.automotiveforums.com/vbul...splay.php?f=65
http://www.automotiveforums.com/vbul...lay.php?f=1146
http://www.toyotanation.com/forum/f22
http://www.4wheelparts.com/forum/default.asp
http://www.pirate4x4.com/forum/forumdisplay.php?f=12
http://mtt.truckmoxie.com/forums
iconhttp://toyotatruckworld.tenmagazines.com/forums
http://4roc.org/forums/index.php
http://www.4x4review.com/discussions/toyota
http://members.boardhost.com/wildrice/
http://www.gator4x4.com/forum/viewforum.php?f=5
http://www.b2g5.com/boards/board.cgi?user=marktoyota
http://www.toyotaownersclub.com/forums/index.php?
http://www.suvfans.com/forums
http://www.network54.com/Hide/Forum/11128
http://www.toyota-parts.com/bb
http://www.toyotaboard.com
http://www.toyotaworld.com/bbs
http://forums.vmag.com
http://groups.google.com/groups?grou....toyota.trucks
http://www.talkaboutautos.com/group/....toyota.trucks
http://groups-beta.google.com/group/....toyota.trucks
http://news-reader.org/alt.autos.toyota.trucks/
http://www.totally-toyota.com/toyota...cks/index.html
http://www.autoforumz.com/Toyota-forum-65.html
http://autos.groups.yahoo.com/group/toyota4runners
http://autos.groups.yahoo.com/group/toyota4runner/
http://autos.groups.yahoo.com/group/the4runner4x4club/
http://autos.groups.yahoo.com/group/4-runner/
http://autos.groups.yahoo.com/group/4runner/
http://autos.groups.yahoo.com/group/wills4runnerworld/
http://lists.off-road.com/mailman/listinfo/toy4x4
http://ar.groups.yahoo.com/group/ClubDaihatsu4x4
These are 6 Canadian based 4-Runner/pickup sites which have free classifieds:
http://www.toyotaoffroad.ca/forum
http://www.toontoysforums.ca
http://www.4wheeler.ca
http://www.bogginfreaks.com
http://www.bc4x4.com
http://island4x4.com
These are 11 Toyota DIESEL 4-Runner/pickup sites which have free classifieds:
http://www.sr5.net/bbs/index.sht
http://www.toyotadiesel.com/phpBB2
http://autos.groups.yahoo.com/group/toyotadieselclub
http://pub12.ezboard.com/btoyotasurfdownunder
http://www.toyotasurf.asn.au/forum
http://groups.msn.com/toyotasurf/shoebox.msnw
http://www.yotasurf.com/forums/index.php?
http://www.yotasurf.co.uk/forums/index.php
http://www.offroadpakistan.com/forum...forum.php?id=8
http://clean4x4.com/
http://jplan.com/cgi-bin/tractor/for...ickup%20Trucks
http://www.biodieselsolutions.ca/
These are Turbo gas based 4-Runner/pickup discussion sites which have free classifieds:
http://autos.groups.yahoo.com/group/22RTE-Trucks
http://www.well.com/user/mosk/welcome.htm
http://www.turboparts.info/pages/620208/index.htm
Sidney® ™
Canada
O
|\ __O
_|_| \
Sidney is offline
Old 08-21-2005, 10:34 PM   #9 (permalink)
Pipe Welder
banshee35's Avatar
View banshee35's Photo Gallery
Just askin, but in years prior to 93, is the speed senso in the instrument cluster?? since the speedo is cable driven and all i was curious. The speedo itself, if you remove it from the cluster, has 2 screws in addition to the 2 holding it to the cluster that have electrical straps in the circuit material, just wondering if that could be a potential problem area.
banshee35 is offline
