The problem indicates that there must have been a problem with the catalytic converter. When catalytic converters fail they normally clog up with debris and block the flow of exhaust gas from getting out of the system. A totally clogged converter will eventually cause the engine to die due to increased backpressure. Usually the only way to tell if a catalytic converter is clogged is to remove it and check the change in engine performance. When a mechanic suspects a clogged converter they may remove the O2 sensor from the exhaust pipe and see if there is a change in performance.
If your friend plans on getting a new converter I have found one that sells discounted
toyota converters she can visit their online store, call their auto parts specialists for any additional queries.
