I have a similar problem with the bed of my 93 extended cab. The frame is straight but the rear of the bed is shifted slightly to the left. I attempted to straighten it by loosening the bolts and giving it a good shove. When this didn't work I removed the bolts completely (not very difficult btw) and then was able to move it. Unfortunately lining the whole thing up again was not easy, it may be that the bed has been bent out of shape, or there just wasn't enough give where the bolts attach. In the end, once I had the mounting points lined up and the bolts fastened down, it was still crooked.
If I were you. I'd get someone else to lend a hand and a pair of eyes. Something that heavy is hard to move by yourself. and that way they can tell you how it looks from one side while you look at it from the opposite. That's what I'm going to try once I get a chance and someone else is available.
