Need some knowledgeable advice. Please help if you can...... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2002, 04:45 PM   #1 (permalink)
View GASRAT's Photo Gallery
I have a 1982 Toyota 4x4 Truck. When I bought the truck it flooded very bad. I took the truck to a guy and he told me that the diaphram was cracked inside my carb so he took a small ball bearing and put it inside the diaphram line which in turn solved my flooding problem. Now the problem that I need help with is that in warm weather the engine will not idle. As long as I am giving the engine fuel it is very smooth, and sometimes the engine will idle on it's own in warm weather, but when I turn the truck off and start it back up it does not want to idle again. I figure that the truck is losing fuel pressure but, and it won't idle until the fuel pressure builds back up. But here is the odd part. On nights when the weather is cool the truck idels perfect, and never even trys to die while idleing. Is their something I can do to keep the truck from dieing in warm weather or some things I can trouble shoot to try and fix this problem. I know this post is quite long, but I wanted to get the problem out so someone may be able to help me. Any help you can provide will be greatly appreciated. Thank You and Have A Nice Day.
OFF ROAD IS THE ONLY WAY TO GO UNLESS YOU ARE DRAG RACING THEN YOU RACE LIKE A CHAMPION AND DRIVE STRAIGHT TO THE FINISH LINE. THOSE OTHER GUYS DRIVE AROUND IN A CIRCLE ALL DAY LOOKING FOR IT.........
GASRAT is offline
Old 09-30-2002, 07:43 PM   #2 (permalink)
View Deep's Photo Gallery
Get a carb rebuild kit and a new diaphram from Toyota and rebuild it.
Deep is offline
