mechanical gauges will interfer with ecu? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2005, 10:02 PM   #1 (permalink)
Official Saipan Member
rogerman's Avatar
View rogerman's Photo Gallery
Question mechanical gauges will interfer with ecu?
Hey guys well i have a 92 hilux 4x4 22R-E so it efi that means it has an ecu correct? ok well i picked up a some mechanical gauges Water temp and oil presure. My question is if i remove the oil presure sender and the temp sender will it mess up the ecu? or will it be fine? thanks alot
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
rogerman is offline
Old 08-20-2005, 11:00 PM   #2 (permalink)
rogerman's Avatar
bump
rogerman is offline
Old 08-21-2005, 12:38 AM   #3 (permalink)
rogerman's Avatar
ok here are 2 pictures i took im looking for the temp sender in pic one there are 2 what i think are sender one is black and the other is green In the other pic the one with the red arrow pointing to it it sits verticaly
rogerman is offline
Old 08-21-2005, 10:59 AM   #4 (permalink)
Pipe Welder
banshee35's Avatar
View banshee35's Photo Gallery
USA Hopefully Helpful
I was gonna do the same thing, put mechanical guages in my rig, 1989 $wd ext cab truck w/ 22re. 1.Could you just get a thermostst housing that has a threaded bung for a sensor in it and use it for the temp guage u r wanting to run? I've seen a lot of these for sale on ebay. 2. On the oil side, I had thought about using a tee so I could still have my idiot light and have the mechanical guage at the same time. I eventuall scrapped the whole idea and got a sr5 style cluster off ebay and swapped it in. All I had to do was to get an oil pressure sender and ajust the tach for the 4 cyl. Very easy to do! and a lot simpler. I personally wouldn't mess with the O.E sensors, They all send info to the ecu in some way.
banshee35 is offline
Old 08-22-2005, 04:46 PM   #5 (permalink)
my poor baby!
bradleyj1279's Avatar
View bradleyj1279's Photo Gallery
what did you do to adjust the tach to 4 cyl?
formerly 88pickup 4WD XtraCab 22RE 5sp. 179K rolled
currently 90pickup 4WD RegCab 22RE 5sp. 153K
Panasonic CQ5410U Profile AP1200 RFp18s4 Pioneer TS-A1371R
brother: 89corolla dx 4AF 5sp. 158K Kenwood HU Pioneer spkrs
once again back in toyota!
bradleyj1279 is offline
Old 08-22-2005, 05:51 PM   #6 (permalink)
Pipe Welder
banshee35's Avatar
By, Newjack"Since the cluster you have came from a V6, you will need to recalibrate the tach for your 22re. this is very easy to do. open up the cluster, remove the speedo, and plug in the unit. with the car running turn the small "white potentiameter" pointing towards where the speedo was. match the rpms with another tach and your done. replace the speedo and enjoy. BTW, don't forget to replace your oil pressure sender with one that matches that cluster. the idiot light sender will fry the 4runner/SR5 oil pressure gauge."
This is very simple to do, only takes a few minutes. So, if somebody tell u it wont't work, don't believe them!
