Hello all
. I have just purchased mt first Toyota 4WD it is a 1988 model with a V6 EFI, 5spd. The truck is in excellent condition no rust what so ever and the A/C works like a charm. The only problem I have is it seems like at times it just does not want to go, hesitates real bad
and other times it runs fine
. It starts right up in the mornings and idles fine I am not sure if it is a fuel issue or ignition issue. I have been told several different things from fuel filter to the throttle body. The young man that owned this truck before did install dual exhaust and remove the Cat. Convertor and I cannot find the O2 sensor in the exhaust pipe, The book shows it to be in the pipe just before the Cat. convertor. Any ideas or suggestions would be appreciated.
Thanks
Jimmy
