84 Toy carburetor - choke or fuel?
My 84 Toyota, 22R with a carb I just switched out to a unit off a running engine. Seems that when cold it fails to want to shoot that little bit of fuel (my best guess) when kicking the choke in. No sound of it coming in at all, but if primed then it roars to life. The truck was parked for 7 years and had run a couple times in between, but the last year or so of sitting clogged the carb up tight which is why I swapped it out. I have had the carb apart 6 times, changed jets, checked floats (window says 1/2 full always) and even tried tweaking the jets to no better off. It had been acting (when cold) like it was sluggish or missing, but that went away and it sounds normal when turned over cold.
Any ideas on this weird issue would be great.
The carb I replaced was a 35270, and the newer one is a 35292 (but identical from the looks)
thanks
Hochy
