1992 Toyota pickup headlight replacement - Special Tools?
Hello all,
I am in the process of buying the subject truck for my son's first vehicle. The dealer wanted $192 to replace the headlights, which have some moisture in them. I have since order a set of conversion bulbs, wiring etc.
Thought I'd do this job, however, my only concern is that I read here: http://www.epinions.com/content_103118442116
A "special tool" is required.
Does anyone know if this is correct, and if so, what is the tool, and if so, where can I get it?
no special tools are required to replace the factory sealed beam bulbs. All you will need is a phillips screw driver and 2 bulbs from your local auto parts store. If you are going to do a conversion then you will need to do some wiring and you will need a soldering iron, solder and some electrical tape. Other than that you should be OK.
to change the bulbs, do u have to pull it out the back, or can you just take off the front lenses by way of the headlight adjustment screws and pull out the bulbs? My lights are really dim, so i was thinking of getting silverstars or something to brighten them up. Its literally almost too dim to tell if they're on, and in high beams, it is not much different.
-Adam
__________________ 1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
I'm not certain if you are asking me about the lights I am converting to, or the old style. My understanding of the new conversion lights I'm attempting to install, they will be accessible from the rear (inside the engine compartment) and I can just pop out the bulb itself, and insert a new bulb into the housing.
I did a lot of reading on the subject and what I think I've learned is:
2. A 200mm (also known as 7 7/8" x 5 5/8" Rectangular Headlight)conversion kit is a good option to get to a brighter, easier to replace headlight system. ($55.00 appx)
I had a '91 4Runner and it had sealed beams. The headlight bulbs werent replacable, you had to replace the whole headlight assembly.
Maybe they changed it in '92 (for your sake I hope so).
All you need to get them out is a phillip's screwdriver.
Cap'n
Originally Posted by Vmax2007
Toyota is not any more "special" than every other company the media has targeted in the past.
'07 Toyota Camry LE
Toyota: Like other cars, only better.
Cap'n
Capt Toyota,
Actually that the entire point of the "CONVERSION" is to provide an easily replaceable bulb, and a significant improvement in lighting, you accomplish this by replacing the sealed beam with a unit like I linked to in the above post.
TTFN
Tim
yeah my 92 has sealed ones that u have to replace the whole unit. Brew did u get the ones with clear fronts where u can see the bulb? or does it look like stock?
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
Mainly because they were on-sale. I haven't installed them yet, but I have received them. They look like they will be good. I'll try to post some pictures after we get them installed.
Probably not as good as these Hella's but considering they cost half as much and were in stock, I'm willing to give them a try.
Well after a heavy engine de-greasing and a bit of cursing at the communist plastic clips that actually attached the grill to our 1992 Toyota Pickup, we have achieved our goal of upgrading the headlights. All in all I couldn't be more pleased with the outcome.
The improvement as phenomenal. The lights are extremely bright and I think the improvement in the appearance is also significant. Here are two images; a before and after:
Before -
After-
And a closeup of the actual replacement light assemble -
I can highly recommend this upgrade, just make sure you include the wiring harness to upgrade your amperage capacity.
oh wow looks like its plastic from the pictures. hmm well you could find a new metal one or you could get the newer styled one from performanceproducts which is plastic but has fog light cut outs.
