Exhaust Leak on 84 truck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2005, 08:44 PM   #1 (permalink)
View toddincali's Photo Gallery
1984 Toyota PU- 22R RN CA 2.4 motor
My truck has no power and has an exhaust leak under the hood. How do I get to the exhaust manifold? Can someone please explain or give me a link to fix this problem. Thank you very much.
toddincali is offline
Old 09-21-2005, 12:51 AM   #2 (permalink)
orange brick
80toy's Avatar
View 80toy's Photo Gallery
remove the front heat shield, all you need is a socket wrench (i think it is 10mm, but i could be wrong) and...BAM, the manifold is right there. JK. remove the front heat shield, check to see if the leak is coming from the manifold block side or by the downpipe. if it is coming from the block, check to make sure all your studs are torqued to the correct specs. mine actually kicked out an entire stud (and took the threads with it). this is a common problem with these trucks. replacing gaskets/checking studs/resurfacing manifold (if needed) should fix it. if you go to tighten your studs, and they don't tighten down, then the threads are toast, and you will need to have that fixed (i think it is called a helicoil?).
if i am wrong someone please correct me. also, maybe Sidney can help you, he has a lot of really good links.
"I'm American honey...our names don't mean shit."
80toy is offline
