stucked distributor 22r engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2005, 05:19 PM   #1 (permalink)
View osum's Photo Gallery
Hello All,
I'm having problems removing the distributor from my old 1983 toyota pickup truck and was wondering if there was a trick that I was missing. I got the TDC mark on the crank shaft pulley lined up to zero degrees, and I even took the valve cover off and made sured that the TDC marks on the the chain/gear thing lined up too, but it won't just pull out like the service manual said that it should. What am I doing wrong or not doing? Any thoughts?
Oh, by the way I did remove the hold down bolt.
Regards,
Kyle
osum is offline
Old 11-21-2005, 02:55 PM   #2 (permalink)
I finally to had to open the valve cover and loosen the bolt holding gear driving the distributor and knock the the distributor out with a heavy hammer and a block of wood!!!
osum is offline
