I have an 82 4x4 shortbed with 217,000 miles, all original drivetrain except for a Centerforce clutch that I installed after purchsing the truck which had been sitting for 2 years from the original owner.It fired right up after giving her some fresh gas and a battery, then sat for another year.This spring I got her going again and threw on a 5" susp.,35" M.T. baja claws for good measure.And of course new plugs,cap,rotor,wires,belts,hoses,thermostat,and fuel filter.Custom bumpers, sliders and even steering wheel.On about my 3rd wheelin' adventure,as I got to the top of the mountain,the truck just died!I limped down because the the truck would run if it was given gas but would not idle.It was a rough trip down not being able to creep over obstacles.Ever since it will not idle or idles rough,then dies.I rebuilt the carb,new fuel filter,checked and checked the timing,and hoses.Removed the cat and still smells like sulfur(forgot to mention that).Tightened the manifold.Checked plugs and they were white at tips indicating a lean mix and that does not go away no matter what i do.After all this it will not idle or will idle rough then die.However, if you give it gas,it will run, but with a lope.There is also a hollow,hissing noise coming from the carb.My dad thinks it is emmisions related,my friend thinks it is the head gasket,and another friend suggest replacing the carb with a Weber 32/36 and getting rid of all emmisions since we have no regulations in Vail.Also it is not a daily driver.Who knows?
