check engine light
1980 4x4 longbed. 20r, 4spd, 113,000 miles. totally stock.
i just got home from a weekend of driving and off-roading. (750 miles). the road miles were chunks of 200 or more with no stops, and at 3000 rpm since i have a 4sp. the off-roading was hard, but my truck did fine. it was mostly crawling and low speed stuff at high altitude (6000 to 7500 feet). my truck never overheated, and never lost any fluids. i just had a tune-up where the fuel filter, wires and plugs were replaced. the oil is also in good shape. i know that it needs a new airfilter. it also experienced a loss of power at the higher altitude since it has a carb. the brakes gave out for a small period of time because the fluid got too hot.
the truck also has an exhaust leak at the manifold because one of the exhaust studs is backing out with the threads.
the wierd thing is that my truck is running fine. it has no loss of power, no wierd vibrations or sounds (other that the exhaust leak). the only indication that something is wrong is the check engine light.
i think that covers it. i assume since there is no change in how the truck runs that it is something simple, i hope.
also, is there any easy way to check to see what the light is by myself, or do i need to take it into a mechanic or a dealer? do you guys have any thoughts or ideas? any help is appreciated.
thank you
edit: EGR valve?
"I'm American honey...our names don't mean shit."
