Battery Cable - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2005, 11:37 PM   #1 (permalink)
View F0RT925's Photo Gallery
USA Battery Cable
Hey There
This Is My First Posting On Here, Ive Got A 1990 4runner And The Neg. Battery Is Kindof Eat Up And I Need To Get A New One But The Factory Want Like $280. For Cause Of The Way Its Got The Wireing Harness On The End Of It. Does Anyone Know Of A Aftermarket Place I Can Get It? Cause That Would Really Help Not Haveing To Pay $300. For It.
Thanks
Gene
F0RT925 is offline
Old 09-26-2005, 01:09 AM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $901064
View humanoid's Photo Gallery
Have you tried your local auto parts store? Try trdparts4u.com. They have pretty competitive prices and great customer service.
This is my sig.
humanoid is offline
Old 09-26-2005, 05:21 PM   #3 (permalink)
USA
Alright Thanks Ill Have To Try That Web Sit. The Parts Stores Said That It Was A Factory Item. Im Also Going To Be Doing Some Engine Work Also, I Thought I Was Getting A Good Deal When I Got This 4 Runner But Now Im Not So Sure About That.
Thanks
Gene
F0RT925 is offline
Old 09-26-2005, 08:32 PM   #4 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Is it just the negative battery cable that you need? You can replace the cable at Walmart for about $15. You can replace both positve and negative and the battery for about $100.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 09-26-2005, 11:34 PM   #5 (permalink)
USA
no the end of it has a wire harness end of the cable that other stuff plugs into
F0RT925 is offline
Old 09-27-2005, 06:24 AM   #6 (permalink)
texas12's Avatar
Sorry for the confusion. Must be a lot different from my '86.
texas12 is offline
Old 09-27-2005, 06:35 AM   #7 (permalink)
USA
yea mines a 90 its a 4 door, not the two door
F0RT925 is offline
Old 09-27-2005, 04:18 PM   #8 (permalink)
View beagledogxxx's Photo Gallery
Just cut the cable a few inches down from the end, buy a new battery terminal end,a piece of cable and a butt splice connector. Strip the insulation off each end, stick them in the butt splice connector and crimp each end. If its good enough for airplanes, its good enough for toyotas. There's no reason that should not work fine. Good luck
beagledogxxx is offline
Old 09-27-2005, 07:26 PM   #9 (permalink)
USA
yea thats more than likely what im going to do, but im just kindof anal about everything on my rides looking the same as the way they came.
F0RT925 is offline
Old 09-27-2005, 08:23 PM   #10 (permalink)
Then make your splice all the way at the other end where it can't be seen. Obviously, the way your ride came wasn't good enough or it would not have failed...maybe you can improve on the toyota engineers design.
Old 09-27-2005, 08:31 PM   #11 (permalink)
USA
mam i wish
F0RT925 is offline
Old 09-27-2005, 08:31 PM   #12 (permalink)
USA
sorry man i wish
F0RT925 is offline
