Re: Vibrating at 65mph ???
Check your driveshaft and make sure all is tight where it connects at the
knuckles. I had a similar problem that balancing and alignment would not
take care of and turned out to be one of the knuckles was very loose causing
it to shake.
Good luck,
Scott..
"marspinball" <martinhirschREMOVEtheSPAM@cox.net> wrote in message
news:YgT2g.5360$Jk2.3736@fed1read03...[color=blue]
> Hi
> My 1996 Tacoma (94k, V6, ext. cab, LX, 2 wheel drive) seems to vibrate
> excessively (truck and steering wheel) at exactly 65mph. On city roads it
> is not noticeable and at about 75mph it does not really seem that bad. The
> tires were replaced about eighteen months ago and have about 10k miles on
> them with very little but even wear.
> What should I have checked out when I take it into the shop??
> Thanks, Martin
>[/color]
