Corolla Check Engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma Lounge
Tacoma Lounge General chit chat for truck owners
Old 10-11-2007, 12:58 AM   #1 (permalink)
View johnsmith2004's Photo Gallery
2000 Corolla CE 75000 miles. The check engine light has been on for almost few months. I tried to use fuel cleaning fluid, but not working. We went to Autozone and the code was P0171 bank1.
I have the code and freeze frame data printed out.
engine spreed 2603 rpm
load value 41.1%
coolant temp 185 F
intake air temp 96F
short term fuel trim 3.9%
long term fuel trim 31.2%
long term fuel trim3 -100.6%
short term fuel trim3 -100.6%
I heard someone said If the Long term fuel trim number is high (over 10).
Then you need a Mass air flow sensor. Is that true? Can I just replace the Mass air flow sensor or also oxygen sensor? Thanks for comments.
johnsmith2004 is offline   Reply With Quote
Old 10-12-2007, 09:39 AM   #2 (permalink)
Anyone can help me? thanks a lot.
Old 10-12-2007, 09:50 AM   #3 (permalink)
View buckerboo's Photo Gallery
Cheapest and simplest thing to try first is to remove the mass air flow sensor, clean it, reinstall it then reset the system. If the light returns with the same code then I would replace the A/F sensor (o2 sensor) bank one. I have not had to replace many MAF sensors, if any. Usually a cleaning of it will work. Worth a try, it is free.
buckerboo is offline   Reply With Quote
Old 10-12-2007, 02:01 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $467667
^^ Do what he said. CRC makes a MAF cleaner that you can buy at any parts store. Make sure not to touch the filament on the MAF sensor.
mikered30 is online now   Reply With Quote
Old 10-12-2007, 02:29 PM   #5 (permalink)
thanks for comment. I will buy the CRC cleaner. How can I clean MAF sensor? By unscrew two bolts, clean insides.
Old 10-12-2007, 08:06 PM   #6 (permalink)
mikered30's Avatar
Try this. http://matrixowners.com/forums/page-1-t27838-s0.html
Old 10-30-2007, 03:39 PM   #7 (permalink)
View c101380's Photo Gallery
I have received the same P0171 code, which is supposed to be for the pre-catalytic converter O2 sensor. I have already pulled out the sensor (which has no corrosion and is showing the correct resistance) but for some reason is still causing the check engine light to come on and give me the same code. I don't know what to do because my O2 sensor appears to be working correctly and I have already cleaned the MAF sensor, changed the gas cap and run fuel injector cleaner through it . Is there anything else that could cause this code ?
c101380 is offline   Reply With Quote
Old 11-26-2007, 12:46 PM   #8 (permalink)
It seems even though people clean the sensors MAF and O2 cannot solve the problem yet. I just heard someone mentione we can clean the oil tank to solve this problem. But, I check the toyota manual, it said the gas tank does not need to be cleaned in the new version of corolla. Anyone can help us how to solve this problem......???
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 10:38 AM
Check engine light help sosuphoenix Celica Forum 2 04-21-2007 04:11 PM
2003 Corolla S - Check Engine light and dealership's runaround... JAlexander86 Archived Corolla threads 13 09-16-2006 07:44 PM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 01:05 AM
92 Corolla Check Engine and Brake Light Help doragio Archived Corolla threads 1 03-23-2004 01:27 PM
