Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - ae95 aftermarket parts
View Single Post
Old 05-06-2006, 11:59 PM   #5 (permalink)
cuzman
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
OK big fella This will work and cost jack..
Version A:
replace your air filter with a high flow washable insert and run pipe(eather use agie pipe or simular) insert it to the air box and run it past the batt down through the guard(theres a hole there already) and hock it up to a air induction vent(already ther) it looks like a vacume cleaner att... this will give you cold air and a ram induction setup!
Version B.
SAme as above but put a pod filter at the end of the line and take out your std filter element......you can also put the pod in the air box if ya like but its a tight fit as you want to keep the lid on so it only gets air from the front of the vechile
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
