Re: Low Brake Pedal-Corolla
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:617ce$445d69a7$180fead6$5407@msgid.meganewsservers.com...[color=blue]
> "Jeff Strickland" <crwlr@yahoo.com> wrote in message
> news:ruqdnXlt-PNVxMDZnZ2dnUVZ_vqdnZ2d@ez2.net...[color=green]
>> You SAID you checked the rear brake adjustment, but this is the single
>> most common problem when the brake pedal has a long travel.
>>[/color]
> The most common cause of long brake pedal travel is worn brake linings.[/color]
That and poorly adjusted brakes.
I see no point in adjusting brakes without checking them for wear first
though, since wear is what makes them go out of adjustment. I suppose I
should advise people to check the brake shoes before adjusting them, but
when one assumes as much intelligence as I assume, some stuff goes unsaid.
Sorry if I assumed the OP was intelligent.
