Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - help with mx73 starting problems?
View Single Post
Old 05-07-2006, 10:53 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: help with mx73 starting problems?
"G Evans" <gereva@interbaun.com> wrote in message
news:125rran165sht01@corp.supernews.com...[color=blue]
> "Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
> news:ce215$445d69a5$180fead6$5407@msgid.meganewsservers.com...[color=green]
>> news:125purblkse9m80@corp.supernews.com...[color=darkred]
>>> 88 cressida, this is the problem wouldn't start last fall, turns over
>>> but no fire up, towed to garage, new rotor cap and wire, works fine till
>>> 2 weeks ago, same thing turns over no fireup, tow to garage, they play
>>> around and finally tell me needs new igniter/coil, they install a used
>>> one works for two start ups then nothing, wait for tow truck, tow truck
>>> driver and I try to start it and it starts, drive for 2 days then guess
>>> what no fire up, waited 20 minutes then fired up went straight to
>>> garage, he says it may have been a loose wire and it should be fine now,
>>> goes 5 days and same thing mechanic visits car he can't start it, he
>>> tows it in to his shop, he tries it at the shop and it starts. says he
>>> can't fix it now that it starts, I take it home it is in my garage, I am
>>> going over the ignition wires with a fine tooth comb right now but would
>>> appreciate any one who can tell me what is going on. I will look at ecu
>>> for loose or damaged wires as soon as daughter gets home with glove box
>>> key.
>>> Thanks, gerry[/color]
>> The place that you are taking the car to seems to think that something is
>> amiss with the ignition system so I'll give them the benefit of the doubt
>> and assume that they are finding a no spark condition.[/color]
> Thats what they tell me[color=green]
>> Engines need 3 things to operate - fuel, air, and ignition, all at the
>> proper moment.
>> What brand are the various ignition parts?[/color]
> original[color=green]
>> Igniters tend to fail for good, not intermittently.[/color]
> That's what I think as well[color=green]
>> Is there any engine oil in the distributor?[/color]
> No.
>[color=green]
>> Ray O
>> (correct punctuation to reply)
>>[/color][/color]
They are going to need an ignition system wiring diagram in order to check
every circuit. I'd suspect the coil or a loose wire somewhere between the
coil and distributor.
Ray O
