Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Low Brake Pedal-Corolla
View Single Post
Old 05-09-2006, 07:41 PM   #15 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: Low Brake Pedal-Corolla
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:a677f$446024f7$180fead6$31158@msgid.meganewsservers.com...[color=blue]
> "Jeff Strickland" <crwlr@yahoo.com> wrote in message
> news:m6CdndxZ5400dcLZnZ2dneKdnZydnZ2d@ez2.net...[color=green]
>> news:7b3d8$445ec5d2$180fead6$18032@msgid.meganewsservers.com...[color=darkred]
>>> news:3aSdnQGra-PZmsPZnZ2dnUVZ_u-dnZ2d@ez2.net...
>>>> news:617ce$445d69a7$180fead6$5407@msgid.meganewsservers.com...
>>>>> news:ruqdnXlt-PNVxMDZnZ2dnUVZ_vqdnZ2d@ez2.net...
>>>>>> You SAID you checked the rear brake adjustment, but this is the
>>>>>> single most common problem when the brake pedal has a long travel.
>>>>> The most common cause of long brake pedal travel is worn brake
>>>>> linings.
>>>> That and poorly adjusted brakes.
>>>> I see no point in adjusting brakes without checking them for wear first
>>>> though, since wear is what makes them go out of adjustment. I suppose I
>>>> should advise people to check the brake shoes before adjusting them,
>>>> but when one assumes as much intelligence as I assume, some stuff goes
>>>> unsaid. Sorry if I assumed the OP was intelligent.
>>> Rear drum brakes go out of adjustment due to brake lining wear, whether
>>> the car has rear drum or disc brakes. Since rear drum brakes need
>>> adjustment due to wear, the root cause of long pedal travel would be the
>>> worn linings, not the out-of-adjustment condition. The rear brakes
>>> auto-adjust by applying the parking brake.[/color]
>> Yes, it a perfect world, the rear brakes would always self adjust (btw,
>> they do this by stopping while going backwards), but the world isn't
>> always perfect.[/color]
> Not all self-adjusting brakes are activated by stopping while going
> backwards. Some are activated by using the parking brake.
>[color=green]
>> The brakes can easily wear while the self adjusters take a vacation, and
>> the recovery action is to adjust them manually to get the pedal travel
>> back in line. Certainly, the brakes can wear to the point they require
>> replacement, but replacement isn't always required when the pedal travel
>> is long.[/color]
> You just made my point that the root cause of the low pedal is wear;
> adjustment is the remedy. ;-)
>[/color]
That's what I said in the first place, you replied that replacement was in
order.
