Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Box Making 101
Thread: Box Making 101
View Single Post
Old 05-10-2006, 08:13 AM   #3 (permalink)
thoughthard
View thoughthard's Photo Gallery
If you want to trim an item, you could use the Liquid Nails in place of the wood glue.
A drill and bit will make cutting the speaker holes easier. Get a drill bit that is big enough that the jigsaw blade will fit into it. Drill some holes around the edge of the circle you are cutting out, but drill them on the inside of the circle. Jigsaw from hole to hole, and cut across to other holes if needed.
my 2¢
thoughthard is offline   Reply With Quote
