Re: Squeaking Clutch
Well, if it really gets bad try going under with a spray can of lithium
grease in the manner suggested by Andy Hill. It may not permanently fix the
problem but it might at least buy you a few months of silence.
Mike Harris
Austin, TX
"grinder" <seagle@earthlink.invalid> wrote in message
news:jOr8g.1055$Jf.874@newsread4.news.pas.earthlink.net...[color=blue]
> "Mike Harris" <harrisremovethiswest@sbcglobal.net> wrote in message
> news:h248g.74369$H71.10828@newssvr13.news.prodigy.com...[color=green]
>> news:5438g.532$y4.134@newsread2.news.pas.earthlink.net...
>>[color=darkred]
>>>I have a '90 4runner. Every once in a while the clutch squeaks like a
>>>banshee when depressed. I had one shop tell me it was the result of a
>>>plastic bushing gone bad. I don't necessarily think so because the
>>>squeak seems to be coming from somewhere underneath the car and that year
>>>does not have the same bushing assembly as later models.
>>> I had another shop said it was normal and could not be fixed. I don't
>>> think that is right either.
>>> I also greased all the joints in the cab to no avail.
>>> I also noticed it squeaks most after I take it to the car wash.
>>> Any ideas?[/color]
>> I'm assuming that you mean a squeaking noise as you mash the pedal; it
>> would occur whether the engine was running or not.
>> That one was addressed by Toyota's TSB TC005-99. It actually calls for
>> replacing the bracket. The TSB lists the part number for the replacement
>> pedal brackets for either 4 or 6 cyl that will cure the problem. The TSB
>> also specifically states not to grease or lubricate the bracket.
>> If it's a squealing noise that occurs as you mash the pedal, that only
>> happens when the engine is running, you probably have a throwout bearing
>> on its way out. If this is the case you may want to live with it if it's
>> an occasional happening. It's not worth going in unless it's very bad or
>> you have some other compelling reason to replace your clutch.
>>[/color]
> Happens regardless if the engine is running. I still think it is odd that
> it only seems to happen or happens worse right after it is washed. In any
> case at this point in its life I will run it until it breaks.
>[/color]
