Originally Posted by hiace24
After comparing my sub to a friends, i am reconsidering the size of my box. The size i have now was suggested by a friend but i am doubting that it is the right size. Can anyone from these specs please suggest the best size box? or suggest a foolproof program to calculate the size.
Power Handling: 300WRMS
Impedance: 4ohms (dual voice coil)
Voice Coil Resistance: 1.7ohm
Vas: 79.454Ltr
Qms: 3.238
Qes: 0.446
Qts: 0.392
Sensitivity: 88.152dB/Wm
BL: 9.992 TM
Fo: 28.77Hz
Sd: 514.720 sqCM
Thanks in advance
What type/size enclosure do you have now and what don't you like about it compared to your buddies? Are they the same subs with the same amps in the same vehicle?
All of the computer programs I use (and have tried) can only calculate a certain alignment in an anechoic chamber. Unfortunately we don't drive anechoic chambers and every vehicle is different so you would need to know the transfer function of
your particular vehicle in order to have an idea of how that sub will respond in
your particular vehicle! This still will not be perfect and if you have a passenger or 2 everything changes anyway!
