Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Toyota Corrola 1984 - Engine Overheating
View Single Post
Old 05-28-2006, 05:49 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota Corrola 1984 - Engine Overheating
"badgolferman" <REMOVETHISbadgolferman@gmail.com> wrote in message
news:xn0emrqa01quccv001@news.readfreenews.net...[color=blue]
> Ray O, 5/28/2006,2:25:12 PM, wrote:
>[color=green]
>> Use antifreeze mixed 50/50 with water; do not use straight water in
>> the cooling system. Make sure that the radiator is full and the
>> overflow tank is filled to the "cold" mark on the tank.[/color]
> Most everyone else says distilled water and you suggest regular water.
> I believe the dealer uses regular water also. What is the "official"
> type of water to use?[/color]
Most people use tap water; distilled water is much better to use. The
original factory fill uses distilled water to dilute the coolant mix and is
good for 3 years. Toyota assumes that most people will use tap water so
subsequent coolant services are recommended every 2 years thereafter. I
have not really studied the newer long life coolants so I don't know what
the replacement interval for long life coolant is.
Ray O
