Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - power steering leak, how to find what part is leaking?
View Single Post
Old 05-28-2006, 05:57 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: power steering leak, how to find what part is leaking?
<dpatwa@gmail.com> wrote in message
news:1148854104.727047.204550@i39g2000cwa.googlegroups.com...[color=blue]
> I'm losing about 6 oz of power steering fluid every 2 days from my 97
> camry. Generally, at work and home where my car sits the longest,
> there is usually a noticable puddle. One mechanic has said that the
> leak is from the power sterring rack and pinion. will mechanics
> replace this or repair it? How do I find out exactly where the leak is
> coming from? is it possible that a there is a bad hose between the PS
> fluid container and other parts? does any recommendations on how to
> better diagnose this since the fix is very expensive?
> -Thanks
>[/color]
It is possible to repair the steering rack and pinion assembly, however, you
need special tools and a very clean environment, and the success rate of
field repairs is not very high so most shops replace the rack rather than
make a low percentage attempt at repair.
You can find exactly where the leak is coming from by cleaning up the leaks
and watching where the power steering fluid is coming from. If you place a
piece of cardboard under the ends of the power steering rack, you can see if
it becomes stained from leaks. The most common places for racks to leak is
at the ends.
It is possible for a hose, hose connection, or power steering pump to leak
but the rack ends are the most common location for power steering fluid
leaks.
As I mentioned, the best way to diagnose the leak is to clean up all of the
previous leaks and see where the fluid is coming from.
You can ask the shop working on your car if they can find an aftermarket
rack or a factory remanufactured rack.
Ray O
